Hi,
I recently purchased and entire PC (prebuilt, I know, shame on me) but regardless, I ran some benchmarks and got normal performance (compared to similarly spec'd systems) But when I downloaded and ran fortnite, it crashed my entire PC every time I tried to launch it. I updated my drivers to the latest (most stable) AMD driver, and that fixed the issue. However, in game, I noticed I could not go any break than the 100-120 FPS range (all epic settings, -motion blur. ) And what especially confuses me is how it dips below 60 sometimes, but only for a bit, the frame rate was VERY inconsistent, often jumping around from 50-120, etc) I turned down the setting, and here's the shocker- NO DIFFERENCE IN PERFORMANCE. Well, a few more frames, but barely noticeable (now its 1080p low, epic view distance) but the frames had a ~5 frame improvement, give or take. I'm truly stumped as to how I can fix this. Thanks.
---Specs---
R7 2700X (base clock)
MSI 5700 XT Mech OC
16 GB Corsair DDR4 (2x8GB, yes, I changed it to 3000MHz in the BIOS)
Crucial M.2 SSD (don't know the name)
I don't really know any other spec that is relevant. Again, thank you for your time and help.
---Specs---
MSI 5700 XT Mech OC
