[SOLVED] Ryzen 2700x vs ryzen 5 3500x help me
Ekron
14
Hello looking to build new pc need some advice the above 2 cpu are available and are in my budget which one should I go for I am only going to do gaming on this pc and the rgb cooler also looks good on the 2700x or should I wait for new cpu the ryzen 5 5600x is too expensive for me help me pls
Hmm, for pure gaming the Ryzen 3000 series are the better option (higher per core performance). I would actually suggest looking at the Ryzen 3 3300X over the 3500X, the 3300X is 4 core / 8 threads (so 2 more threads than 3500X) and has all 4 cores in one CCX which gives it a bit of a boost in games. It's the best budget gaming cpu, if you can find one should cost a similar amount to the 3500X.
If you buy a b450 (or preferably a B550)...
If you buy a b450 (or preferably a B550) motherboard you will also have the option to upgrade to a 5000 series cpu in the future if you want to.
Thank you very much but will the 3300x bottleneck? I am planing to use rtx 3070
