Ryzen 3 1200 problem
onii_chan
56
As i ran a prime95 stress test, my ryzen 3 1200 only maxed out to 3.07 ghz, eventhough it has a boost clock of 3.4. My temps stayed during the stress test under 53C. Is my motherboard the issue?
Motherboard: AsRock A320M-DGS
CPU: ryzen 3 1200 @stock
RAM: 8GB ddr4-2133 Single stick
May be you have enabled in the BIOS the "Cool'n'Quiet" option:
Cool 'n' Quiet
Use this item to enable or disable AMD’s Cool ‘n’ QuietTM technology. The default
value is [Enabled]. Configuration options: [Enabled] and [Disabled]. If you install
Windows®
OS and want to enable this function, please set this item to [Enabled].
Please note that enabling this function may reduce CPU voltage and memory
frequency, and lead to system stability or compatibility issue with some memory
modules or power supplies. Please set this item to [Disable] if above issue occurs.
