[SOLVED] Ryzen 3 2200G error Red debug LED
Jan 19, 2019
First of all my PC Specs :
Ryzen 3 2200g
MSI B450 Gaming Plus
Team T-Force Delta RGB 2x8 GB 3000 Mhz
SAPPHIRE NITRO+ RX 590 Special Edition
PSU Deep Cool 700W 80+ Bronze (DA-700)
WD Green 120 GB SSD
WD Blue 500 GB HDD
RGB fan 6 x 12mm
When first time I build the PC is working fine with 3,7 Ghz OC on Ryzen 3 2200G. I use it nearly 16 hours daily about 1 month, because I build this PC on December.
The problem come when I play games for 6 hour non-stop and the computer go black screen. When I see the motherboard, the debug led is all goes on and then the CPU debug LED keep showing while the others are off, the CPU fan also not working. I try to fix it plug off the CPU and add new thermal paste and plug it in again, the problem is still showing.
Can you help me diagnose the problem ? I think the Processor is burning because of overheating, so the motherboard cannot detected it. If that's happened do you have any suggestion to fix the problem ?
Thank you
Jan 19, 2019
sadly I don't have another CPU to test it, thanks for your respond.
Similar threads
