[SOLVED] Ryzen 3 2200g help
ljonzeey33
Commendable
Jan 14, 2019
52
New pc build just installed windows 10 and when I download latest driver 19.1.1 from amd soon as it's installed the screen starts going black every few seconds. Any advice on this?
My specs are:
ryzen 3 2200g
Asus prime a320m-k
Corsair vengeance lpx 2x4gb 2666mhz
I had asrock board and there was information to avoid bios update if using old version of amd drivers... maybe it's other way and the drivers used by you are not compatible with older bios version? I would update bios if I was you.
No it does it on windows and bios only way to fix it was to reinstall Windows 10 is from fresh, but I can't get the Vega 8 to display in device manager? I'm using a hdmi
