Ryzen 3 2200G + Monitor 22" 1080p or Ryzen 5 2400G + Monitor 20" 900p ?
Sep 7, 2018
5
In two months I will build my entry level pc. I am confused on the same budget There are two choices, the first is Ryzen 3 2200G + Monitor 22 "1080p resolution or Ryzen 5 2400G + Monitor 20" resolution 900p?, Which one is prioritized first, monitor or processor? Help me get out of this problem. Thanks before...
People tend to keep monitors for a much longer period of time than the PC box. I think you're better off with a 1080p monitor over the long run.
About $ 480 in my country. Thank you for the answer. Yes, I also agree more looking at the monitor resolution. I know that the processor is also important. But when else can I feel 1080p, for the processor I can upgrade later.
