Hey guys I needed your help
So I recently bought a rx 5704gb asus expedition for my ryzen 3 2200g
My full specs are
ryzen 3 2200g(overclocked to 4ghz with +1.44volts using bios)
Rx 570 rgb
2133mhz 8gb ram(oce'd to 3200mhz )(dual channel)
A320m s2h mobo
Cooler master 550w psu
My problem is I am not getting the performance as expected I saw a bit yt vids for the build and those people are getting better fps than mine on the same settings even on 1366x768p
For example on csgo that guy was getting 250+ fps and I am getting only 150avg
Amd in pubg I get 40-50 fps where this guy is getting 70-90
It would be a very good for me if you can help me
The vid(you can see pubg and csgo benchmarks)
View: https://youtu.be/y9zjIAVSo4k
+He has 16gb ram so I don't think it will be a lot of difference between 8 and 16
My full specs are
Rx 570 rgb
A320m s2h mobo
