I'm trying to build a pc and I've been researching parts and compatibilities and it is a bit overwhelming for a first time builder.
Currently I'm looking at this: https://pcpartpicker.com/list/Wmb9Cb
My intent is to build a 2200g, throw in a gpu when I can afford it and upgrade to a 1600 after a few months capable of playing and streaming to twitch at the same time. Please note that I'm not trying to budget build AROUND the 2200g, the main focus is the 1600, but obviously these parts need to work with the 2200g until I can afford the upgrade.
I mainly play League of Legends and Blade and Soul, and I really want to play Rainbow 6 as well.
What I'm not understanding is which ssd, mobo and ram are compatible with both the 2200g and the 1600. I'm a little stressed about it looking over QVLs and not understanding what I'm looking at.
I'm reading that the b350 pro4 (https://pcpartpicker.com/product/yBtWGX/asrock-ab350-pro4-atx-am4-motherboard-ab350-pro4) is a good mobo but 3200 ram won't run on it, but I also read that ryzen needs high ram speeds to work well so to me it sounds really confusing. other boards I've liked are the b350f (https://pcpartpicker.com/product/ZHyxFT/asus-strix-b350-f-gaming-atx-am4-motherboard-strix-b350-f-gaming) and the x370 killer (https://pcpartpicker.com/product/LgmxFT/asrock-x370-killer-sliac-atx-am4-motherboard-x370-killer-sliac). I liked the x370 for the onboard wifi since wifi adapters are also confusing with mixed reviews, but on the other hand I've read that anything below the r5 1600x doesn't really benefit from an x370 over a b350. To top it all off, the QVLs surrounding ssds are also another language.
So, my overall question/concern is: which ssd, mobo and ram will be compatible with BOTH the r3 2200g and the r5 1600 w/ a dedicated gpu?
What are my best storage options?
Can I run the x370 with both chips and not need to worry about an outside wifi adapter?
If I should jus topt for a b350 and need a wifi adapter, which adapter actually works well and will last me some time?
Budget is irrelevant. I just want no issues with my first time assembly.
Thanks for any input!
