So I just put together a system using a 3400g on an asrock x570m pro4 with 2x8g gskill ripjaw 5 3600 ram. I know overkill, I'm just using this untill I get money for a better cpu and a dedicated gpu. I've been messing around with it for the past two days and can't seem to get it to work right. It will boot to windows fine with the ram at 3400 mhz because going over crashes the system. When I run any bench or stress test everything seems to hold though I think I'm not getting the full performance from the igpu. Next I loaded up a couple games, first being beamng and the thing chugs like my old laptop. Then I tried loading up csgo because even a potato can run it, and it crashes when it gets to the main menu. And when I mean crash, it shuts down and gets stuck with the fans full blast and I have to turn the system off with the psu. Then I tried running arma 3 a very cpu bound game, in the sandbox editor it seems to run buttery smooth but when I load up a scenario ie. apex missions, it get to loading the environment and crashes like csgo. After all that I tried running at 2933 mhz, the advertised max ram speed the 3400g can take, and tried even 2133 mhz and both have the same crashing issue as before. So my question is, is there anything I can do to make it work fine? Or did I just mess up on the hardware combination and I'm gonna have to start from scratch?
ps all drivers and software are up to date along with mobo bios and misc device firmware.
asrock x570m pro4
ryzen 3400g
2x8 gskill ripjaw 5 3600
mushkin 2tb nvme m.2
rosewill glacier 1000w bronze
noctua nh-u12s
silverstone kl-06b
asrock x570m pro4
ryzen 3400g
noctua nh-u12s
silverstone kl-06b
