Question Ryzen 3600 with MSI tomahawk Max not working.
Sep 27, 2019
12
Well my MSI tomahawk max wont even get me to bios menu. Everything seems to work fine. Fans working AIO working ram on place, even the LED's work fine and do not give me the static red light which indicates that there is something wrong with the cpu. Yet again i dont get an image. What is happening?
Sep 27, 2019
12
Yes and that's the strange. Cause that's why I bought it so I won't mess up with cmos and bios updates. So take the battery off for like 10 minutes.. put it back and flash my bios with everything mounted?
Sep 27, 2019
12
Well after resetting cmos and and putting new bios in. After like 4 to 5 minutes it went of so it can reopen and show me that there is no boot device detected
Sep 27, 2019
12
Plus the red led indicator that shows that an update is running is just static red now along with the static no boot device led
RodroX
Upstanding
Aug 4, 2019
342
99
290
You do have image on the screen right?, thats were you read the "no boot device found" message, then you need to go into BIOS, by pressing Delete or F2, and choose the right boot device, or start from a pendrive to with a Windows 10 image to install it on your SSD or HD.
Reactions: TJ Hooker
Sep 27, 2019
12
The no boot device it's an indicator of the motherboard. Like the flash bios update indicator.red led lights static after the update of the bios
RodroX
Upstanding
Aug 4, 2019
342
99
290
Oh, my bad then, so its one of those mobos with a display on the PCB, I didnt have time to search on internet,
I would try a new BIOS, if theres new one to apply, and I will also do a clear cmos before and after applying the BIOS update.
Sep 27, 2019
12
I did clear it and after I flashed the newest bios. But when it finishes it suppose to close the red indicator. Not being static
Sep 27, 2019
12
Not that is not damaged already... "Ryzen 3000 ready" what's the point of paying more for something new that will have 3000 ready and get into trouble with bios and cmos shit..honestly msi
