Question Ryzen 3900X overheating in idle ?
Mar 12, 2024
4
Hey guy I need your help. I am running a Ryzen 9 3900X cooled by an AOI NZXT kraken X73 for around 3 years now and in the last like 3 months I am getting really high temps (like 85C while in idle, going up to 95 while doing anything and then of course clocking down to not go over 95 C. I tried to change the thermal paste, updated cpu, chipset and fan software. Cleaning every fan and so on. I don’t know what else I can do, so please help…
From NZXT CAM software, what RPM the pump is and what RPM the rad fans are?
Since it most likely is one of the three:
1. Too low pump RPM (or even pump failure)
2. Too much liquid evaporation (happens as time moves onwards)
3. Too low rad fans RPM (not enough cooling for the rad)
Fixes to try:
* pump RPM to 100%
* rad fans RPM to 100%
If doing the two doesn't fix it and you still get the high temps issue, it's time to replace the AIO. While NZXT X73 is high-end AIO, they still last 3-5 years. So, either get a new AIO, or better yet - air cooler. Since with air cooler, their lifespan is essentially unlimited. Because only thing that can go bad on air cooler is the fan on it and replacing one 120/140mm fan is both cheap and easy. While with AIOs, you have to replace the entire thing and new AIO is expensive (usually more expensive than air cooler is).
Fixes to try:
* pump RPM to 100%
I tried putting RPM all the way to the max, but it didnt change anything.
Could there be an issue with the radiator or the fluid inside the AIO. And if yes, how could I test it?
Best you can tell, is what NZXT CAM software reports. It may report fluid temperature and flow meter, but that's about it. As far as i know, it doesn't report fluid amount. And if it did, there is 0 way for you to open the AIO and add more fluid. AIO you have, is closed loop and not meant to be user serviceable by adding more fluid. Only fix is buying new AIO.
What kind of AIO would you recommend to get as an replacement?
Personally, i don't favor AIOs.
As far as AIOs vs air coolers go, you won't gain any cooling performance if you go with AIO over air cooler since both are cooled by ambient air.
For equal cooling performance between AIOs and air coolers, rad needs to be 240mm or 280mm. Smaller rads: 120mm and 140mm are almost always outperformed by mid-sized air coolers. Single slot rads are good in mini-ITX builds where you don't have enough CPU cooler clearance to install mid-sized CPU air cooler.
Here are the positive sides of both (air and AIO) CPU cooling methods;
Pros of air coolers:
less cost
less maintenance
less noise
far longer longevity
no leakage risks
doesn't take up case fan slots
additional cooling for the RAM
CPU cools down faster after heavy heat output
Pros of AIOs:
no RAM clearance issues*
no CPU clearance issues
CPU takes longer time to heat up during heavy heat output (about 30 mins)
* on some cases, top mounted rad can give RAM clearance issues
While how the CPU cooler looks inside the PC depends on a person. Some people prefer to see small AIO pump in the middle of their MoBo with tubing going to the rad while others prefer to see big heatsink with fans in the middle of their MoBo.
Main difference between AIO and air cooler is that with AIO, you'll get more noise at a higher cost while cooling performance remains the same.
Here's also one good article for you to read where former king of air coolers (Noctua NH-D15) was put against 5x high-end AIOs, including former king of AIOs (NZXT x61 Kraken),
link: http://www.relaxedtech.com/reviews/noctua/nh-d15-versus-closed-loop-liquid-coolers/1
Personally, i'd go with air coolers every day of the week. With same cooling performance, the pros of air coolers outweigh the pros of AIOs considerably. While, for me, the 3 main pros would be:
1. Less noise.
Since i like my PC to be quiet, i can't stand the loud noise AIO makes. Also, when air gets trapped inside the AIO (some AIOs are more prone to this than others), there's additional noise coming from inside the pump.
2. Longevity.
Cheaper AIOs usually last 2-3 years and high-end ones 4-5 years before you need to replace it. While with air coolers, their life expectancy is basically unlimited. Only thing that can go bad on an air cooler is the fan on it. If the fan dies, your CPU still has cooling in form of a big heatsink. Also, new 120mm or 140mm fan doesn't cost much and it's easy to replace one. While with AIOs, the main thing that usually goes bad is the pump itself. And when that happens, your CPU has no cooling whatsoever. Since you can't replace pump on an AIO, you need to buy whole new AIO to replace the old one out.
3. No leakage risks.
Since there's liquid circling inside the AIO, there is always a risk that your AIO can leak. While it's rare, it has happened. It's well known fact that liquids and electronics don't mix.
However, if you're adamant of still getting an AIO, then further reading,
article: https://www.tomshardware.com/reviews/best-cpu-coolers,4181.html
2nd opinion: https://gamerant.com/best-aio-coolers/
3rd opinion: https://gadgetmates.com/best-360mm-aio
Arctic Freezer II has reviewed well as one of the best AIOs.
