Golden silicon is still golden silicon...I have one of the first lots of 3700x's so all brass here but I'm content anyway.
Also..that 3800x...all core 4.5G? at 1.33V fixed? wow...so long as he's happy watching a $400 dollar processor melt away I guess. I'm not all that bothered about multi-core performance, my lowly little 3700X single thread score, 512, is pretty much identical to his. Single thread helps the games more so that's the important metric to me.
And yah, chasing big 'maximum performance' numbers is a game played for it's own sake. The marginal cost of a 'chiller' for getting a couple hundred more points on CB20 multithread becomes astronomical and utterly impractical IMO. But people do it...so whatever floats your boat, I guess.
If you are going to get a really big custom loop with multiple big rads and lots of expensive fans. Then just getting one chiller can be 'cheaper'. The gpu will be bought with its own water block and is not a part of the loop but I still have bought its rad and the minimum to get it running with the CPU. I also avoided expensive distro plates to keep the cost down. Also I got a bay reservoirs because it was cheaper, another no-no.
Just put together for ball park price.
Quantity Stock ID Description Price Total
WC-01Q-CS Corsair Hydro X Series XR7 480mm Quad Fan Water Cooling Radiator (CX-9030006-WW) £129.95 £129.95
WC-842-EK EK Water Blocks EK-CoolStream XE 360 (Triple Fan) Radiator £98.99 £98.99
7 WC-9GB-EK EK Water Blocks EK-Vardar EVO 120ER Black BB (500-2200rpm) Fan - 120mm £14.99 £104.93
2 WC-9AK-EK EK Water Blocks EK-Cable Y-Splitter 3-Fan (10cm) £2.99 £5.98
WC-551-EK EK Water Blocks EK-Cable Y-Splitter 2-Fan PWM (10cm) £2.99 £2.99
WC-443-XS XSPC Raystorm NEO CPU Water Block (AMD) - Black Chrome £79.99 £79.99
TH-020-TG Thermal Grizzly Kryonaut High Performance Thermal Paste - 1 Gramm £5.99 £5.99
WC-686-EK EK Water Blocks EK-DBAY D5 PWM (incl. pump) £134.99 £134.99
8 WC-255-XS XSPC G1/4" to 1/2" ID, 3/4" OD Compression Fitting (Black Chrome) V2 £3.95 £31.60
2 WC-46L-XS XSPC FLX Tubing 1/2" ID, 3/4" OD (19/13mm) - 2m Clear £7.99 £15.98
3 WC-9P9-EK EK Water Blocks EK-CryoFuel Clear 1L Premix Watercooling Fluid - 1 Litre £7.99 £23.97 WC-995-EK EK Water Blocks EK-ATX Bridging Plug (24 pin) £1.99 £1.99
WC-9EJ-EK EK Water Blocks Filling Bottle (1000mL) £6.95 £6.95
Total £644.30
Not cheap. Now a chiller. Like the water cooling just the CPU.
waterchiller Hailea Ultra Titan 300 (HC250=265Watt cooling capacity) £362.98
Brennenstuhl Power socket adapter for UK/DE £3.53
2 connection adaptor for Ultra-waterchiller 300 500 1500 to G1/4 £5.80 £11.60
EK D5 Vario Pump & Black Monsoon D5 Cover Combo £99.95
4 WC-255-XS XSPC G1/4" to 1/2" ID, 3/4" OD Compression Fitting (Black Chrome) V2 £3.95 £15.80
5 WC-9P9-EK EK Water Blocks EK-CryoFuel Clear 1L Premix Watercooling Fluid - 1 Litre £7.99 £39.97
Total £637.78
Used sources.
Leading the way in bespoke PC systems and PC gaming, any and all of your components & peripherals needs are met with our vast range of products and services.
www.overclockers.co.uk
liquid cooling for PCs from Aquatuning: ✚ Huge selection ✚ Points consultation & support ✚ Fast dispatch ✚ Super price-performance ratio!
www.aquatuning.co.uk
Costs change with the addition of the graphics card. The two rads are so the water block can be changed and an Intel waterblock added for 9900K overclocking. For 9900k watercooling the rad should be changed to a
Watercool MO-RA3 360 PRO stainless steel £199.48 https://www.aquatuning.co.uk/water-...tercool-mo-ra3-360-pro-stainless-steel?c=2742 The amount of fans increased. 9 x WC-9GB-EK EK Water Blocks EK-Vardar EVO 120ER Black BB (500-2200rpm) Fan - 120mm £14.99 each fan or 18 x WC-9GB-EK EK Water Blocks EK-Vardar EVO 120ER Black BB (500-2200rpm) Fan - 120mm £14.99 each fan. For the AM4 system I would go for a monoblock covering cpu and motherboard which should be more expensive and add a GPU with its own waterblock (cost for gpu part of gpu price). You can increase the chiller to waterchiller Hailea Ultra Titan 1500 (HC500=790Watt cooling capacity) to add the GPU (£571.72 https://www.aquatuning.co.uk/water-...an-1500-hc500-790watt-cooling-capacity?c=2745)
As soon as you go for an extreme water loop, the cost of a chiller is not so bad. Remember most good looking water loops use a good looks distro plate. EK-Quantum Reflection Evolv X D5 PWM D-RGB Distro Plate £229.99 https://www.overclockers.co.uk/ek-w...5-pwm-d-rgb-distro-plate-plexi-wc-9y6-ek.html Also its wise to have two pumps. A case designed for the water cooling loop which is very expensive. You can save this money with a chiller, you have to use soft tubes and the chiller can only go outside the case. A distro plate wont make things look any better.
If your insanely expensive cooling hits over £1000, then just get phase change.
