I finally got all the parts for this build about a month ago. When I put it all together it initially wouldn't post. I troubleshooted a lot and ruled out issues with the cpu, gpu, and ssd. I borrowed some memory from my brother that we know works, and it finally posted and booted. I installed windows on it, gave my brother his memory back, and then moved across the country with the pc. Now I ordered the same model of memory we used and installed it, and...no post.
I know the monitor and hdmi cord both work and I plugged the hdmi cord into the gpu, not the mobo. When I turn it on all the fans run, and the ez debug lights go on and off until it hits the boot light, which stays on. I plugged a keyboard into the usb and that lights up, but pressing delete/f10/f11/f12 doesn't work. I've tried letting it run for ten minutes or so and still nothing. I double checked all the connections and I still have this problem. I'm new at this so I would really appreciate some help.
CPU: Ryzen 5 1500x 3.5Ghz
Mobo: MSI B350 Tomahawk ATX AM4
Memory: Corsair Vengeance LPX 2x8 GB (slots 2 and 4) DDR4 3000Mhz
Storage: Seagate Barracuda 1TB HDD
GPU: EVGA GeForce GTX 760 4GB SC
Power supply unit: OCZ 600W
