P Pcenthusiast16 Commendable Mar 27, 2016 275 0 1,790 Jun 17, 2017 #1 Ive heard alot of conflicting reports about ryzen 5 and ram so could someone tell me if the above configuration will work or bottleneck it in anyway etc.
Solution Forever Oleg Jun 17, 2017 Ryzen uses DDR4 memory. As long as you use DDR4 memory (such as 2666 or 2400) with the appropriate AM4 motherboard, you will be fine.
Forever Oleg Admirable Jul 15, 2015 3,280 0 8,960 Jun 17, 2017 Solution #2 Ryzen uses DDR4 memory. As long as you use DDR4 memory (such as 2666 or 2400) with the appropriate AM4 motherboard, you will be fine. Upvote 0 Downvote Solution
Hellfire13 Titan Apr 20, 2016 15,223 1,113 92,740 Jun 17, 2017 #3 Ryzen performs better with higher RAM... https://www.toptengamer.com/best-ram-amd-ryzen-5-7-cpu/ Upvote 0 Downvote
