Question ryzen 5 2600 - Asus motherboard Q fan settings
ss_56
291
7
18,795
My ryzen 5 2600 idle temp is 47C says my Asus motherboard. Is that too high? I went into asus Q fan and set the wraith cooler to "turbo" and the temp dropped a couple degrees. Should i leave it on turbo or what? Thanks
Sep 15, 2019
86
8
65
It isnt that high of temperature though. Try to monitor the CPU tempertaure using HWinfo etc and get a perfect reading in idle and load (gaming or rendering) condition. If the CPU reaches above 80 or 85 there might be some problem. But 47 idle is common plus many Ryzen 5 2600 stated that their CPU reached 40 to 45 in idle which was normal.
