Question ryzen 5 2600 double power consumption than i5 4570. Why?
bobalazs
332
14
18,865
i5 config is : Asrock H81M-VG4 i5 4570 2x8gb ddr3 1600 mhz
intels cpu is 84w tdp,
amd config is: Gigabyte GA-b450M S2H Ryzen 5 2600 2x8 Gb ddr4 3200 Mhz
amd's is 65w.
the mobo+cpu+memory changed only and also added 2 more 12 cm case fans.
the b450 chipset supposedly eats about 5W.
he B450 chipset runs a lower powered integrated controller which reduces the idle power draw by just under 2 W, from 6.8 W to 4.8 W.
ddr4 has lower power consumption than ddr 3 supposedly
The Intel configuration's power consumption was 39W idle intel power picture
The Amd's was 76W Amd power picture
Everything running on full auto, no OC, changed clocks to default fix 3400 Mhz, no difference.
power consumption in bios 84w bios power consumption picture
Aida64 FPU stress test
Intel 88W intel aida fpu
Amd 123W amd aida fpu
Furthermore, when i left everything on auto in bios, raised the CPU clocks to 37.75, I got 170W from the meter by benchmarking with linpack only. https://logout.hu/dl/upc/2019-08/110225_explorer_2019-08-03_04-34-00.thumb.png
amd's is 65w.
Maybe bios isn’t stable yet just wait for bios update and see what happens
