[SOLVED] Ryzen 5 2600 Max Voltage?
cgplays
46
Hi, I'm currently running a Ryzen 5 2600 CPU on my MSI B450 Mortar Titanium, with a Noctua NH-D15 for cooling and I need some advice on overclocking. So originally i bumped the voltage up to 1.4, and the highest clock I was able to get 1.41. I then was able to bring the voltage down to 1.875, as when I try to bring the voltage above 1.4, the text in the BIOS goes red. I just wanted to know what is the safest voltage I can go to for the CPU + Cooler I have, and what clock I will be able to achieve with said voltage.
In terms of airflow, i have a Fractal Design Meshify C, three Thermaltake Riing 12 Blue CPU Fans (Two intake up front, 1 Exhaust at the back), and I put the 2 Fractal Design fans that came with it up the top as exhaust.
If any other than what is disclosed is required to come up with a conclusion, just let me know. Thanks in advance!
~Adrian
