Help needed!
Hi guys,
I have just installed a new mobo and cpu, Gigabyte AB350 gaming and a Ryzen 5 2600. I have installed the fans and applied thermal compound. the compound was applied over some older dried up compound but thats all i can think of. Anyway, the CPU is heating up like mad, its lowest temp at the moment is 76°C with the highest at 95 °C while running cs:go.
the cpu is not overclocked at all and the latest BIOS update is in place.
Any help from you guys would be massively appreciated!
Thank you.
Here are some pics for further clarification.
Hi guys,
Thank you.
