Hello! I'll start by apologizing in advance if I ask any stupid questions, it's my first attempt at building a PC.
I recently purchased an AMD Ryzen 5 2600x processor which I paired with a B450 Tomahawk Motherboard from MSI. I put it all together, but i am getting some strange readings from my CPU frequency.
When I first put it all together the only thing I messed with in BIOS is A-XMP profile (basically selected profile 2 which boosts my DRAM frequency to 3200, as I've mainly understood it significantly helps Ryzen performance).
First thing I did after installing a fresh OS (windows 10) was check my temperatures.
I was somewhat shocked to see my cpu @45-55 idle, and rising easily to 75-85 under workload (tested with some games like GW2 which is on the heavy side of CPU resource consumption and benchmarks of Aida64), this being caused by the fact that my CPU is CONSTANTLY running at the maximum frequency of 4.2 GHz which I don't want to have especially using the stock cooler (wraith spire). Having 1.4 V+ constantly running through my CPU when 50% of the time not even 20% of that is needed seems useless and I'm concerned it will shorten the lifespan of the CPU.
This is a screenshot of my BIOS configuration, it's clearly on AUTO and (please correct me if i'm wrong) there should be no reason my CPU reached more than 3600 MHz with this, since it's not OC'd.. right? (also cool'n'quiet is active)
So basically, for some reason, my CPU is always at maximum frequency, regardless of workload.
What I did to go around this was play with the power plan configuration, and set the maximum CPU usage to 95%. This lowers my MAX frequency to 3200 MHz.
I should mention that any value in the 85-99% I use for "max" will always cap my frequency at 3200. At this point the frequency on all cores starts to oscilate between 2200 and 3200 RANDOMLY and CONSTANTLY.
Even with no workload the frequency will not drop below 2200
Question is why is this happening?
How can a not-Overclocked 3600 CPU reach 4200?
At this point I'm not sure if it's a configuration issue or maybe a piece of hardware is actually broken?
If anyone has any idea and a minute or two to hint what might be the issue here your time will be greatly appreciated. Have a good one!
