[SOLVED] Ryzen 5 3600 and compatible motherboards..
Sep 19, 2021
24
Does ASrock B550 Pro4, ASrock B450 STEEL LEGEND and GIGABYTE B550 GAMINX X (rev. 1.0) motherboards need bios update to work with ryzen 5 3600? Also if you know more budget motherboards and good coolers which works well with ryzen 5 3600 feel free to suggest me since i heard that cooler which comes in box with 3600 isnt that good.
400 series chipset mostly need BIOS update, depending on date of production, 500 series do not need BIOS update.
i would go between B550 Pro4 or Gaming X. for cooler, Hyper 212 Evo is good enough, or Noctua NH U12s.
Reactions: kurdtnz
I would go with B550, for Gen4 PCI-E for storage, and GPU slot, 3.0 from the chipset, and better I/O in the back. Cooler, a Vetroo V5 is inexpensive, and does quite well. I am using one, on my 5800x, right now.
I think i've decided for gigabyte b550 gaming x (rev.1.0) and hyper 212 black edition (😅 sorry for bothering you this much ) i have bought hyperx predator 16GB kit , and just to get ryzen 5 3600, and a better power supply and im done with pc upgrade.My GPU is rx 570, its not really special but i think it will work nice with this system for now.I also plan upgrading it in future.
Is cooler master hyper 212 black edition better than hyper 212 evo? because evo isnt available.Also what about cooler master sickleflow 120 ARGB , its cheap but is it good for ryzen?
I can vouch for sickleflow, it's a fantastic low noise cooler. Certainly better than masterfans.
As of mobo, b550 boards shouldn't need bios update even for zen 3.
Don't go with hyper 212. They were the goat. Not anymore. Cryorig h7 is better at price point. Hyper 212 has one of the worst mountings
sickleflow is cheaper and is available but cryorig h7 isnt available in my country like the rest of good coolers and idk why, also i read that hyper 212 BLACK EDITION is a lot better than hyper 212 evo because people all over internet say that its noticeably quieter and easier to install because fan quality is also improved.So its either gonna be the sickleflow or hyper 212 black.
Sickleflow is case fan. I was talking about sickleflow case fans. Not sure it has cpu cooler
