Hi, is it normal for this cpu to drop to 3600mhz under load?
I've seen countless benchmarks showing cpu clock speeds and they all seem to hold their boost speeds. Mine however will drop down to 3600mhz and back up again, randomly. It doesn't drop for long but it shows up in Afterburner. With pbo enabled I see around 4.350 to 4.4ghz under light load and around 4.100 under heavy load but it will always drop to 3.6ghz randomly, even tho cpu usage is at 20% and above..
For example 3dmark timespy will show cpu frequency after the bench has finished and will have dips to 3.6 on the purple line..
Is this normal? Like I say online benchmarks from other users are usually around 4.1 and higher without drops to 3.6.
