My new ryzen 5 3600 is having cpu temp flucations, and high idle temps. I reinstalled the cooler and I have the same result as last time. Going from 44 degrees celsius to 56 degrees Celsius is not normal, especially when am doing nothing but running windows. The bios tells me that my temps are around 30 degrees Celsius, but msi command center says it is way above that(44 to 56 degrees Celsius). I have not overclocked anything at all. I have a MSI B350 PC mate and I’m using the stock cooler. I have a wraith spire on hand that I could switch to. Any ideas or suggestions would really help.
