Hi, I recently built a new system with a Ryzen 5 3600 and a Cooler Master Hyper H411r from my old system. Idle temps are around 50-55c but when testing using AIDA64 my temps jumps from 50c to about 80c instantly and just hits a ceiling and stays there for the whole duration of the test. Completely stock no overclocking or undervolting done.
Ryzen Master is installed but I did not touch it.
I also did not set or change anything in the bios, only thing I did is enable XMP and nothing else.
Specs:
Specs:
- CPU: Ryzen 5 3600
- CPU Cooler: Cooler Master Hyper H411R
- Mobo: ASRock B450M steel legend
- RAM: Patriot Viper RGB 3200Mhz
- GPU: Asus rx470 strix OC 4GB
