So a couple weeks ago I upgraded to am4 and got the ryzen 5 3600 and I just left settings as is except for after updating drivers I enable Ryzen balanced power plan. So my question is whenever I check hwmonitor, just it being open nothing else. the clock speed is about 4174, so 4.2ghz which I think is the boost speed. so should I keep it like this or should I go into bios and disable the boost clock speed?
My system specks are :
Ryzen 5 3600
Msi x570 Mobo
Msi rx570 8gb
Corsair vengeance pro rgb 3200
Corsair h150i pro rgb cooler
Also with these settings and this cooler I get about 36C on idle while some cores are going to sleep in and out as there is no other programs running. What kind of setting should I have it on? thanks for any responses.
Ryzen 5 3600
Msi x570 Mobo
Msi rx570 8gb
