Built this system yesterday with a new Ryzen 5 3600 CPU (using included cooler and thermal paste), and its temps are idling at mid 60's with my case closed (no programs running besides Ryzen Master, nothing downloading in the background, tested for 20-30 minute segments across several boots). Since I didn't like the temps spiking to the mid 70's to low 80's when opening simple applications, etc., I decided to just take the side of the case off for the time being and use a small external fan blowing in the PC.
Even with the external fan and side panel removed I am idling at low to mid 40's, which might not sound too bad, but pretty much any game I play has me at 80C+ within an hour. No Man's Sky reached 92C within minutes, so I'm unable to even play that game safely. I mean Prime95 hit 92C in 3 minutes... basically same results as No Man's Sky. I have had both case fans and the CPU fan set to only run at 100%. Enabling XMP and setting the fan strengths are the ONLY changes I have made in the BIOS. The CPU (and mobo and GPU) clock speed and voltages are running at stock.
When installing the cooler to the CPU I made sure to only begin to thread the first screw before only starting the diagonal one, so on and so forth. It's receiving equal pressure on all 4 screws and I made sure to double check that before I even put the board in my case.
I'm honestly pretty stumped here. I hear about others using the stock cooler and achieving much lower temps. I wouldn't even mind the idles so much if I weren't averaging in the low 90's by simply playing a game (while blowing extra air into the system). I mean I was just running an FX 6300 before upgrading. Same case, same case fans, a better cooler (hyper 212 LED), and it was overclocked to a constant 4.5Ghz stable with 10C to spare at thermal margin even at the worst case scenarios. Obviously the cooler helps there but still... how am I hitting the danger zone with this CPU at stock settings?
Specs:
CPU: Ryzen 5 3600 (stock settings)
GPU: EVGA GTX 1070 Superclocked (stock settings)
MB: ASRock Fatal1ty B450 Gaming K4 (stock voltages)
RAM: CMW32GX4M2C3200C16 (default XMP profile: 3200 Mhz C16)
PSU: Rosewill Green Series RG530-S12 530W
Case: Rosewill Tyrfing (1 intake fan on front, 1 outtake fan on back)
Specs:
