[SOLVED] Ryzen 5 3600 Temps
Henryjones2724
11
Hello all,
I have recently just installed a Ryzen 5 3600 in a b450 Mobo with the stock cooler. My idle temps are around 50C with a Cenebench run going around 87C. Are these average temps or are mine a bit high. Nothing is overclocked besides XMP enables on 3600mhz ram.
My CinaBench score was a 3342 as well for all cores
Thank you,
Henry
@Henryjones2724
I think the temps are on the high side. What are you using to measure temperature? I would prefer you use hwmonitor or hwinfo as they will give you more info. This could be a hot running CPU, a poorly mounted cooler, or a poorly calibrated thermal sensor.
