[SOLVED] Ryzen 5 3600 + Wraith Prism idle temps
Antrophin3
12
Is it ok for stock speed temps at idle to be 45-50C, using the Wraith Prism Cooler?
The mobo is ASUS PRIME X470-PRO latest BIOS 5603 (Date: 07/28/2020).
Under load they don't go over 71C...
I also tried under-volting to 1.250 core V or setting Voltage Offset to -0.0625, still the same... using AIDA64.
HWinfo shows the sam Tdie temp, so is it normal or not?
If it's not over 71 under load is fine. Idle is really irrelevant since terminating Corsair iCUE alone causes a 2-3° drop on my H212 RGB. Idle has too many variables and too less significance, worry about load Temps, which at 71 seem perfectly fine
