[SOLVED] Ryzen 5 3600x and B450 Tomahawk MAX
gigabyte06
60
Picking up a 3600x to use for our church streaming services. Is the B450 Tomahawk MAX still a good MB to use or are there other options in the same price range? I will also be using a NVIDIA GeForce GTX 1660 in the build if that matters. Thanks
Yes still best with b450 chipset nut you might have to update BIOS. Luckily it has a button for that and could be updated even if CPU is not compatible at first.
