[SOLVED] Ryzen 5 3600X Need Help in choosing parts!! (budget is tight **)
Koushal Saini
237
Greetings,
Since i got a 5-7 year old PC. I have finally decided to upgrade my PC.
I am Planning to buy "-
CPU- R5 3600X
MOBO- ASROCK b450M PRO4 OR GIGABYTE B450M DS3H or any other Cheap Possible
PSU- Corsair VS550
RAM- F4-3200C16D-16GTZRX or F4-3200C14D-16GFX other Cheaper then this.
Please Help me choosing the RAM, its very confusing.
i did some research on my own gskill official says "F4-3200C16D-16GTZRX" is compatible with Both b450 Mobo i have mentioned but the official site doesn't show this ram.
Help Please!!!
Please gimme opinions for what to buy and what not to for all parts.
I live in India.
Change the PSU to a cx550m, or Vengeance series. VS are not good quality. Just grab a regular 3600. The performance difference is negligible, and saves you $50, that you could put towards a better motherboard, like the MSI B450 Tomahawk. Keep in mind, any B450 will need a bios update, to use that CPU.
what is the budget?
if it is 5-7 years old pc I suspect that the ram is DDR3 so you can't reuse that part.
for the ram you want fast ram like 3200 mhz cl16 is pretty good choose.
Greetings,
CPU- R5 3600X
PSU- Corsair VS550
Help Please!!!
Is there any other ram recommended for R5 3600x and also supported with motherboard?? Please leme know.
Even if there is any better motherboard then these 2(cheap) please mention.
Reactions: Koushal Saini
Msi b450m pro vdh plus or Msi b450m pro vdh or asrock b450m pro4 ???
Have decided to get 3600x, cooler master MWE 550 watt psu, same gskill 3200 cl q16 ram and finally need help choosing 1 of these 3 mobo or one around 7k inr.
Unless you are able to verify which BIOS the motherboard will come with, those boards may not support Ryzen 3000 without an update (which would require an older CPU). The motherboard I linked to has a feature that allows you to update without a supported CPU.
The 3000 MHz kit I found seems to be a fair bit cheaper than any 3200 MHz kits. Performance difference won't be that much.
Unless that PSU is the MWE Gold version, it's not very good. As has been said already in this thread repeatedly, don't cheap out on your PSU. Step down from a 3600X to a 3600 if you need to in order to get a good PSU within your budget.
