Question Ryzen 5 5500 problems
Oct 22, 2023
4
Would anyone know why my cpu is not giving the right fps? Now a pin from one of the rows on the side did break but I’ve been able to do everything just fine, but in warzone which ik it’s not the best cpu for the game but it’s enough for 60hz at 1080p, but the thing is it isn’t it struggles to maintain 60 fps and drops to the fourties’ and each time I see a video showcasing it, it could well reach 100 frames, I’m also working with a 2070 super and 16 gb 3000 so I shouldn’t really be struggling but would anyone know why? Could it really be the one missing pin? I’m using a b450-f II for the MOBO as well and I have it clocked at 4225 in bios
which pin exactly?
to have a look what the problem could be:
run userbenchmark.com and post the http link of your result, e.g. https://www.userbenchmark.com/UserRun/28977730
undo any OC
Reactions: ebrieon
which pin exactly?
undo any OC
the pin could vary from being white,dark green,light blue,and the dark yellow/orange and the benchmark with oc is right here https://www.userbenchmark.com/UserRun/65064001 ill respond again with the non oc scores
no oc: https://www.userbenchmark.com/UserRun/65064138
update your Bios to the latest version 5201 and set the Ram back to 3GHz using EXPO in Bios
you will have to identify the exact pin on the diagram
could be limiting the Ram speed
run memtest86+ installed on an USB flash drive
(use autoinstaller to get it on the stick)
memtest passed heres the new results with everything, figured out my fps problem but ram is still doing its thing take a look https://www.userbenchmark.com/UserRun/65097545 but anyways i think i just accept the rams fate at this point it is most likely the missing pin causing it but thank you nonetheless for all of your help!!
Did you install the RAM into DIMM slot A2 and B2?
That will probably do it, problem with that is it doesn’t boot if i remember when I first built it like that, the vga light turned on and everything of course was loud til I reset it, and only booted on when I switched them to A1 and A2, I’ll attempt to switch them to the recommended slots but I don’t believe the B2 will work, I’ll edit once I have attempted
Edit: nothing booted when I did so
