Question Ryzen 5 5600h enough for RTX 3070?
Razvan96
53
I am interested in a acer nitro 17.3 worth 1200$ with Ryzen 5 5600h and rtx 3070 but not sure if that cpu and gpu are in bottleneck...Would run the gpu better than a 3060 or cpu will limit the gpu? I can't find another laptop at this money with rtx 3070 so i am not sure if it worth the money.
What is the screen resolution and refresh rate? What are you going to run on it?
A faster GPU is a faster GPU. Overall performance will be better no matter what.
Obviously if you were targeting a higher frame rate, than a faster CPU would be better. But if you are going after high resolution or quality gaming at lower FPS, than you would want to prioritize the GPU.
Is ACER Nitro 5 AN517-41-R3LH . Fhd and 144hz. Mainly shooter games.
