I did a fresh install of windows, hoping to get rid of any past settings. is this right?
say
stock ; 3701
current ; 4649 while idling ...
say
stock ; 3701
????? that's truely a peculiar...and LOW... clock speed!...
My current 5600x idle speed according to Ryzen Master is 180mhz.
There will always be background tasks to work on. You can only do so much but you cannot get rid of everything, which will cause the periodic spikes that @drea.drechsler mentioned.I'd recommend disabling everything you can do without in Windows Settings "privacy" as a starting place to reduce idle processes and then look at any software you've loaded that runs in the background even when not in use.
Wow...I have to wonder if that's 'real' as in an actual, measured clock speed. Or, as I'm thinking, an 'effective' clock speed...something like HWInfo's "Core / Thread Effective Clock". To quote what HWInfo says about it: "Average clock calculated across the polling period with respect to sleep states. This value much better reflects the dynamic state of the core/thread. Very low values are normal when the core is idle." (emphasis added)Imgur: The magic of the Internet The clocks do run pretty low but seriously ramp up when needed, this was taken with 3 tabs open on windows.
Does RyzenMaster average clocks now?
