Ryzen 5 issue with RAM running at 3200...
sepota
75
Hi
This is a complex one...
I have a Gigabyte AB350 Gaming 3 with a ryzen 5 1600
Just got this ram, which is compatible (ref G Skill site)
G.SKILL Flare X Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) AMD X370 / B350 Memory (Desktop Memory) Model F4-3200C14D-16GFX
I d like to run at 3200, using XMP or manually OC it if needed
People are running it at 3200 out of the box with xmp when reading review for it on newegg, using the same MB, example:
Pros: Very fast. Works at 3200 out of the box with Gigabtye AB350 Gaming 3 just have to enable it on BIOS.
Another one:
Installed in a Gigabyte GA-AB350 Gaming 3 mbd w/ a Ryzen 5 1600x. The XMP profile loaded without issue and the system is stable.
This review is from: G.SKILL Flare X Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) AMD X370 / B350 Memory (Desktop Memory) Model F4-3200C14D-16GFX
Pros: Runs at rated speeds and is compatible with my motherboard.
So right now, RAM is running at 2400 (not 3200), and hardware reserved ram is at 8.1G...
Won t boot with XMP...
Bios is latest (F8)
Any hint on what I could do?
Thanks
