Hello gentle(wo)men,
I recently bought a Ryzen 5 PRO 4650G as an upgrade to my 2200G, but alas it doesn't seem to work on my Asrock B450 ITX MB (no signal to momitor).
I thought as they are both AM4 it would be supported by my board.
Should have done some more research before buying this chip, as I see now that the 4650G is not on the support list for my MB (while the 5000 series are).
I already updated my BIOS to 4.10 (AMD AGESA Combo-AM4 PI 1.0.0.6 ) even though that is not adviced for my current (raven ridge) cpu (which still works fine).
I can still try to update to 4.20, maybe that will help (or harm my current set-up)?
Or should I give up as it is not on the list ?
Or should I contact Asrock to as about support of this cpu?
Is there anything else I can do to make this CPU work (like other RAM, reset BIOS), as I don't even know if this CPU even works?
I could ofcourse buy a new MB that officially supports 4650G, but that defeats my purpose of a cheap cpu+gfx (apu).
Any help/advice is welcome.
Best regards,
Dominique
Best regards,
Dominique
