Ryzen 5 temperature under full load.
johnseredgar
Hello everyone I was playing fortnite yesterday and my cpu was at 99 percent load and my temperature was at 79 Celsius. I have the stock cooler and nothing in my pc is overclock. The room temperature is at around 75 fahrenheit. Is this temperature normal for 99% load or should I buy another cooler? Also my gpu temperature was at 77 Celsius at around 70 percent load if that matters. Thank your in Advance.
Pc info
Ryzen 5 1500x (stock cooler)
Gtx1070
8 gb of ram Ripjaws
3 cases fans
Warm, but you're fine with the Ryzen. (1) They are safe at higher than previous AMD CPU core temps. (2) It depends on what temp on which app you were monitoring it. Some temp apps don't read the correct location for Ryzen.
https://www.kotaku.com.au/2017/03/amds-ryzen-cpus-arent-running-as-hot-as-they-say-they-are/
