Question Ryzen 5700g w/ RX 6600 not achieving optimal fps
Feb 21, 2022
7
I just built my first pc and it is not getting the fps that I saw other people with similar builds are getting.
CPU- AMD Ryzen 7 5700g
GPU- MSI AMD RX 6600 Armour 8G
RAM- XPG D60g rgb 16gb 3600mhz cl18 dual channel (2x8gb) kit
PSU- Aresgame 850watt 80+gold
COOLER- Jonsboro CR1100 rgb dual fan 6pipe cpu radiator cooler
I’ve already tried setting the cpu to 4.55ghz, ram 3600mhz, GPU maxed. I can catch 40fps on warzone medium setting 1080p
I will run default settings and update.
Fans are set on auto and never reach max speed, and all my temps look to be in what’s a normal range.
sorry for not being more descriptive just still trying to get around my system
