Hello,
I am trying to upgrade my system, when the following problem came up.
With previous CPU (Ryzen 2700x), system boots up fine, the 2 stock fans on the case works fine,
However when I replaced my old CPU (2700x) with the new Ryzen 5700x, the system could not boot up, restarted every time, not even the monitor could turn on, could not enter bios either. Also, the 2 stock fans were not starting up.
Tried with bios update (incrementally even, from 4.10 to 5.60). Nothing changed. No boot, restart, fans not working. Tried clearing CMOS. Same outcome.
When I put back the 2700x, everything worked (with it I could update the bios).
First I thought, okay, faulty CPU, got my money back, bought the same version (5700x) from somewhere else (cheaper even). But same outcome. Nothing worked.
Could it be something that I overlooked, or does it seem, that the motherboard should be replaced?
Thank You in advance for any help!
SPECS:
motherboard: Asrock B450 PRo4 (not r2.0 and not 450M version)
CPU: Ryzen 5700x
cooler: Be Quiet PureRock 150W TDP
PSU: Seasonic Focus GX-650
GPU: GeForce GTX 1660 TI (for now)
case: Be Quiet Pure Base 500 with 2 stock fans
SPECS:
CPU: Ryzen 5700x
