i have a new build, specs are as follows with cooling:
5800x3d cooled by an arctic freezer 2 360 aio ( fans are exhaust)
asus rog strix b550 f gaming wifi 2 mobo
4 lian li infinity 120 mm fans 3 front are intake one exhaust rear
asus ko 3060ti gpu
ram is mushkin redline 32 gb
psu is thermaltake 850w gold gf3
1-1tb mushkin 5400 speed os nvme drive
1- 2tb mushkin 7400 speed game nvme drive
case is nzxt h7 flow
the cpu idles at around 50 - 60 , under gaming even non impactful games it gets to 76
i know they are a warmer running cpu but with me being disabled i fret that something is wrong, i had a live call with the companty that built it they did a stress test through remote access with occt (i think thats the name of the program) for 10-15 min and the cpu hit 77 max on quiet fan setting and they said thats great thermals but im a worry wart and like multople opinions, but im so used to my old cpu with an air coller sitting at 38-40 at idle and never hitting 75 while gaming but that was a r5 3600 also
am i over thinking it or is there something wrong? if theres something that doesnt look right what can i do to check, im a stroke survivor with super shaky hands so im not comfortable messing around inside the case ill break something so reseating the aio repasting i wouldnt be able to do that , any advice would be great ive attached a pic of hwmonitor of it being idle aftyer playing agame so u can see the max temp and idle or should i be using a different program to monitor ?
View: https://imgur.com/a/FlaMZ19
asus ko 3060ti gpu
