Parts list:
https://pcpartpicker.com/list/nMcT74
My Ryzen 9 5900X runs too hot even with a Deepcool Castle 360EX 360mm AIO.
Manual throttle limit set via bios to 88c and it will reach and sit at 88c throughout gaming, and it idles above 60c. Currently, I have PBO turned on with curve optimizer with the following settings (Which are lower than what they would be set to stock, in an effort to run cooler)
PPT: 125 TDC:85 EDC: 130
Curve optimizer is set per core, with the best core being set at -12 with every subsequently ranked core set -2 more (eg -14, -16, -18 so on) With these settings, it is stable and scores a 1048 multicore, 94 single core, 11.15x MP ratio in cinebench r24 multicore. It is not overclocked aside from these pbo settings. Ram is set to DOCP 3600mhz. Case has two intake 120mm noctua fans, and two exhaust 120mm noctua fans. AIO pump is set to run at max as well as the 3 fans on the radiator, which max at 1200rpm.
Stuff I've tried:
I have tried lowering PBO settings, defaulting bios settings, PBO off, fan curves blasting across the board, re applying thermal paste, (no, the plastic sticker is not still on the aio lol) conversations with ChatGPT, moving case fans around, all intake, 2:1 intake to exhaust and vice versa. Don't really know what else to try.
Full HWiNFO64 Readout: View: https://imgur.com/a/YQwqmdg
I've had this PC for over two years and always come back to this issue and try to resolve it, but haven't had any luck getting it to run much cooler than it is without undervolting and sacrificing performance. Is the aio just bad?
Edit: I should also note that during Cinebench R24 multicore runs with the above PBO & Curve optimizer settings it only hits 74c-77c. Single core runs it hovers around 83c-86c.
Any help is SO appreciated, help me solve this years long problem lol
Stuff I've tried:
