Ryzen 7 1700 and 1070ti build!
Oct 19, 2018
Hi,
i am looking to build a gaming computer and also stream on the side, im set on the ryzen 7 1700 and a 1070ti. I need a good motherboard for it preferably a B350 on the cheaper budget side, i have been looking at:
https://www.amazon.co.uk/dp/B06XMXVMCH/?coliid=I9D17PPEF4YOC&colid=8NLAZ3XJCSJ7&psc=1&ref_=lv_ov_lig_dp_it
https://www.amazon.co.uk/dp/B06XNPW8JC/?coliid=I1YN8DL4DFX9CD&colid=1T8VD4AM8EWEB&psc=1&ref_=lv_ov_lig_dp_it
and finally https://www.amazon.co.uk/dp/B06WVFFXXL/?coliid=I1YN8DL4DFX9CD&colid=1T8VD4AM8EWEB&ref_=lv_ov_lig_dp_it&th=1
which is my best choice and i've heard that some don't boot as the bios is too old, i would like it to boot from the box so if you know which board allows me to do that , it would be much appreciated
thank you!
But thats the gaming 3 mobo, whereas the one on the list is the gaming only one?
