Ryzen 7 1700x High Temps
docov06
44
Just built a new rig with Ryzen 7 1700x inside, on a Asrock Fatal1ty X370 Pro Gaming mobo. Cooling it is a Corsair H60 AIO water cooler. Running idle, using HWMonitor, its reporting temps at 50-55c. During normal browsing, it will hit 60c. And after running a Cinebench R15 test, it maxed at 68c. Reading other threads, I found out that there was an issue causing the temps to be read 20c higher than what they are. Is that what I am experiencing? I also flashed my BIOS from 1.5 to 2.4, with the same results. BIOS and HWmonitor state that the water pump is running at 4100rpm.
Download AMD's Ryzen Master and check your temps with that. Ryzen Master will automatically adjust the temps to the actual giving you an accurate temp. If Ryzen Master shows the temps you are seeing with HWMonitor then those are the real temps.
https://www.amd.com/en/technologies/ryzen-master
EDIT: As of note checking Ryzen Master vs HWmonitor 1.31 on my System (Same motherboard, BIOS, and processor as docov06). HWMonitor's temp are not adjusted on my system. HWMonitor reported 57C Ryzen Master reported 37C.
