PC SPECS
CPU: RYZEN 7 2700
PSU: SILVERSTONE SXF 600W 80+ GOLD
MOBO: ASUS STRIX B350 - I GAMING (BIOS VERSION= 4011)
RAM: HYPERFURY X DDR4 @2133
COOLING: AOI ID COOLING FROSTFLOW 240
GPU : EVGA GTX 1070 SC
Hi guys I recently purchased a R7 2700 (non x) with the view to overclock. The first thing I done was to try Ryzen master to get a rough idea of where my cpu max oc was before I attempted an oc in the bios. In ryzen master I can oc to 4.0 on all cores @ 1.4v stable however...... when i get to the bios i cannot change the voltage I can ONLY set an Ofset. In the bios it shows a base voltage of 1.0 volts seems to be locked ... In CPU Z it shows a core voltage of between 1.100 to 1.145 fluctuates. Am i right in amusing that in order to boot I will have to set an offset of 0.3000 in order to get to the desired 1.4v which will allow a boot. I had set the multiplier to 40 and had dialled in all other settings the max offset i have tried is 0.2000 all resulting in a failed boot . I must add that I have successfully booted at a lower speed of 3.8 at an offset of 0.2000, Im just concerned that an offset of 0.3000 maybe to high even-though ideally i need 0.3500 to be sure of stability.Finally Load line calibration has been set to level 2 of 5 levels. Any help would be greatly appreciated.
CPU: RYZEN 7 2700
