Question Ryzen 7 2700x Build and i7 9700k Build quick review for each if possible
Mar 30, 2019
Trying to weigh up which build i'm going to end up going with and just want to make sure there's nothing that raises any red flags for compatibility issues or anything.
Both gpu's are just a (temporary) 1050ti at the moment. mobo's are probably a bit overkill, and if so any other good suggestions? I was originally going with an ASUS b450 f but got turned away after hearing a few rough reviews, so just thought it would be worth paying a bit extra for some better features.
Intel:
Ryzen:
Mar 30, 2019
The Asrock board has onboard WiFi so unless you really need the extra speed, you don't need the WiFi card.
Yeah, its just that I've heard that some people have had problems getting their onboard wifi to have a decent connection in situations where a wifi card has with no problems, so I'll probably just play it safe and get a card by the sounds of it.
