Question Ryzen 7 7800x3D not booting, mobo stuck at GPU beep ?
Jul 21, 2023
7
So, I bought a new Ryzen 7 7800X3D, 32gb DDR5 ram and a gigabyte B650M Aorus Pro Ax. My computer refuses to boot, I've tried everything, even the on board integrated graphics aren't working, neither my RTX 2070 Super. I even tried another motherboard, but got the same error. I don't know what do now, at this point, I think the problem is the CPU. It refuses to boot at all costs...
View: https://www.youtube.com/shorts/shwxaJL64Zg?feature=share
View: https://www.youtube.com/watch?v=oiZw_c1WY_0
I'd get with AMD customer support because they should have the answer. Return it and get a refund? Should work good. Everything is compatible mainly the barebones of the Motherboard and CPU.
I got with them, still waiting for a reply. I do think that my CPU is working fine, it's just that something isn't correct. The mobo is stuck at VGA light forever.
Reactions: PaulC55
I've even tried different bios in both motherboards, the latest ones, by flash bios, without success.
I think my RAMs are the problem, since it's a chinese brand (Kingbank) and not listened as compatible with my motherboard. I bought a 16gb kingston hyperX fury beast KF560C40BBA-16 to test it.
I was going to say I got very good support from NVidia but that’s a different story. Asus is ok and I’m not sure if I have had tech support from AMD. I usually try to do phone tech support because I don’t really like texting even in chat support but I do if I have to. The MB is stuck at VGA light forever? What is the VGA light? I know about VGA. That’s the old port of video cards, PC Monitors going back to CRT and LCD TVs with the VGA port for hooking up a laptop or desktop for a second display.
That's on the video. The mobo first checks the cpu, then DRAM, then VGA, and finally, boots. Unfortunately, mine is stuck at VGA stage.
Check this video.
View: https://youtu.be/oiZw_c1WY_0
