Question Ryzen 7 9700X idle temps ?
punisher_09
67
Hello! I got a new AMD Ryzen 7 9700x CPU. Using the HWinfo64 software I saw that while idling the minimum CPU(tctl/tdie) temperature is around 42*C, and maximum is around 69*C, while gaming (Stalker 2). I would like to know if this temperature while idling is normal ?
While running OCCT, with all cores at 100% load, the max temp of the CPU is about 65-66*C.
The rest of the PC is:
MB: Gigabyte B650 Gaming X V1.3
Cooler: ID-Cooling FROZN A620 PRO SE
RAM: 2x16 GB DDR5 6000MHz
GPU: RTX4070 12GB DDR6
2x M.2 PCI-e SSD's
1x S-ata SSD
1x S-ata HDD
PSU: Super Flower Leadex 2 gold 650W
Fans: 2x200mm intake and 2x140mm on the back and on the top of the case.
2x M.2 PCI-e SSD's
1x S-ata SSD
1x S-ata HDD
That's just Tdie temperature, look at core temps (more important) they are all up to ~25c. The rest is due to memory controller (IMC) as you probably have XMP/EXPO enabled.
