Ryzen 7 & MSI b350 tomahawk issues
TKWH
11
i built my first computer yesterday. today i downloaded and tried out all my games, and im a little disappointed. lets start with what im running things at, Ryzen 7 1700 with gaming mode on so 3.4ghz
2 sticks of 16gb ram running at 2133 *its the 3000mghz corsair model but my computer had a hard time starting up which was very odd so i clocked it back down and a GTX 1060 EVGA 6gb FTW+. now for the story, i was playing csgo, everything at high and all the crap filtering's off. i noticed on EVER map i played i was only getting an average of maybe 95 fps. and some times, i would see it go 45 for a split second and other times see if go 140! im running on bios e7a34ams.150
update- checked ram was running at 2133 at the time of this at 1.184v, i also quick changed my ram speed to 2400 and tested it, i was getting about 50 fps!! why is this !
my friend thinks i have a faulty motherboard with bad voltage issues.
do i need to update my bios?! . thanks
MERGED QUESTION
Question from TKWH : "issues with MSI b350 tomahawk and RAM"
2 sticks of 16gb ram running at 2133 *its the 3000mghz corsair model but my computer had a hard time starting up which was very odd so i clocked it back down and a GTX 1060 EVGA 6gb FTW+. now for the story, i was playing csgo, everything at high and all the crap filtering's off. i noticed on EVER map i played i was only getting an average of maybe 95 fps. and some times, i would see it go 45 for a split second and other times see if go 140! bios running at e7a34ams.150
do i need to update my bios?! thanks
MERGED QUESTION
Question from TKWH : "cpuz is saying my ram is running at 1199mhz"
It's DDR (Double Data Rate) memory so your 1199MHZ (that Cpu-z shows) means 1199 x 2 = 2398 true MHz. You can not get round number because Ryzen MBs run FSB/BCLK at 99.8 - 99.9 MHz instead of 100.
MERGED QUESTION
Question from TKWH : "ryzen having to restart my computer to fix fps"
Have you downloaded and installed the latest AMD Chipset Drivers that include the AMD Ryzen Balanced Power Plan?
http://support.amd.com/en-us/download/chipset?os=Windows+10+-+64
wow, this might be the only driver i haven't installed, thanks so much!
It's suppose to fix the core parking bug that affects gaming performance.
