Hello guys,
I bought a new pc two days ago. I mounted everything up, hardware and software wise everything is good except that i cant overclock my ram memories.
My build is as follows:
Motherboard: Asus Rog Strix X470 f Gaming
Cpu: Ryzen 7 2700x
Ram: 2x8gb G.Skill Trident Z (TZRX)
Gpu: Msi GTX 1070ti
Cpu Cooler: Msi frozr XL
Ssd: Samsung nvme 970 evo 500gb.
I have updated bios to 4024 version.
I tried setting the d.c.o.p profile 1 with ez mode bios and it set the memories to 3200 but it doesnt boot.
I tried manually and also increased voltage point by point from 1.35 default to even 1.45 and still not bootable. I didn't touch timings.
Everything was on auto except the settings i did manually on ram.
The only stable memory speed is when i set them at 2666 which i run the pc with.
Also my Cpu is running at 4.3ghz without setting any overclock but its temps are around 50 to 60 Celsius within black ops 4 with every graphics setting on max at 1440p. Fps varies from 80 to 110 fps.
If you guys have any solutions/advise it will be much appreciated! Thanks for your time!
Cpu: Ryzen 7 2700x
Gpu: Msi GTX 1070ti
