AMD to let media publish reviews of Ryzen 7000X3D on February 27.
Ryzen 7950X3D May Run Slower Than 7800X3D, Reviews Rumored for Feb 27th : Read more
....is this actually news?
It was same on the 5800x vs 5800x3d
more cache, but clocks slower.
Is speculation derived objectively from currently available factual data actually throwing shade?I knew this was an Anton article just based off of the title 😆 he an Aaron never pass an opportunity to throw shade towards amd
Pay more, get less, LOOLThe "news"/leak is that the 7950X3D's 3D CCD is slower than the 7800X3D. It was expected to be the same (5.0 GHz boost).
Last week we learned that transpired that the Ryzen 9 7950X3D is actually slower than the Ryzen 9 7950X in Blender and Geekbench 5 and apparently this might be a result of lower clocks on the CCD equipped with additional cache.
In games like World of Warcraft the 5800x3d is the number 1 cpu, just because of the cache. Counter-Strike at 1080p the 5800X3D was outperformed by the standard 5800X.
Stuff like this is why I won't buy an X3D CPU. I really don't like the idea of spending lots of money on a CPU that is only faster in specific applications and actually slower in other.
If I'm buying a newer CPU, I want a flat performance increase. No "ifs" and "maybes".
Higher clocks gives me a flat performance increase I can count on. Cache is very fiddly regarding which applications actually benefit.
Dude, you can get 200 fps on a 10-year-old potato CPU in these games.
Do you have an intel CPU with E-cores? They are not always better than their prior parts because of the nature of adding in smaller cores. There are still applications that will bump over to the E-cores when they could be on the P-cores resulting in less theoretical performance. This is very similar in what AMD does with X3D cores vs normal cores. There are always going to be growing pains when you have some cores do something better than others on the same CPU.Stuff like this is why I won't buy an X3D CPU. I really don't like the idea of spending lots of money on a CPU that is only faster in specific applications and actually slower in other.
Does the other CCD still boosts up to 5Ghz?The "news"/leak is that the 7950X3D's 3D CCD is slower than the 7800X3D. It was expected to be the same (5.0 GHz boost).
The implication is that the multi-CCD CPUs have a lower boost clock on the cores with the higher cache than the 1 CCD 7800X3D.Does the other CCD still boosts up to 5Ghz?
This is going to be the key thing to find out.The implication is that the multi-CCD CPUs have a lower boost clock on the cores with the higher cache than the 1 CCD 7800X3D.
again depends.Higher clocks gives me a flat performance increase I can count on. Cache is very fiddly regarding which applications actually benefit.
Do you peeps already have samples to test during the weekend?AMD to let media publish reviews of Ryzen 7000X3D on February 27.
