[SOLVED] Ryzen 9 3900X build help
Oct 20, 2021
Hi,
I'm coming out of a tech coma where after my last build I stopped paying attention to what was going on with parts and such for 2+ years and just want to make sure I am not missing something with this build. Im not 100% on the PSU and want to make sure I understand that I need to do a BIOS update with my board in order to use my CPU. Any other general advice or just confirmation that this will function properly together would be appreciated.
CPU: Ryzen 9 3900x
Case: Fractal Design Meshify 2 Gray Mid Tower (comes with 3 fans and looks like it has good air flow so might not need additional cooling)
GPU: MSI Radeon RX 6900 XT (yuk on that price T-T)
Mobo: ASUS AMD AM4 ROG Strix X570-E Gaming (listed as being good with the Ryzen 9 in my quick research)
Memory: G.SKILL TridentZ RGB Series 32GB DDR4 3200
PSU: Corsair RM750x 750W (I think this one has the right connectors, cant seem to find one with lower wattage that has the ones I need)
Am I missing anything obvious? Any conflicts or incompatibilities?
Appreciate any feed back, just dont 100% trust myself rn.
I am assuming this is a gaming rig? If so, an R7 5800x would be a better solution. It would require a bios update, and Asus's flashback utility isn't very good. I would suggest Gigabyte instead. Unless you really have a need for all PCI-E lanes to be gen 4 PCI-E a B550 would be a better choice, with regards to better rear I/O. 750w might be a bit low, with that combination, under heavy loads. I would do something like this.
PCPartPicker Part List
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor ($393.99 @ Amazon)
CPU Cooler: Thermalright ARO-M14G 73.6 CFM CPU Cooler ($49.99 @ Amazon)
Motherboard: Gigabyte B550 AORUS PRO V2 ATX AM4 Motherboard ($189.99 @ Newegg)
Memory:...
Memory: Crucial Ballistix 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory ($169.99 @ B&H)
Video Card: Sapphire Radeon RX 6900 XT 16 GB NITRO+ Video Card ($1609.98 @ Newegg)
Case: Fractal Design Meshify 2 Compact TG Light Tint ATX Mid Tower Case ($122.98 @ Newegg)
Power Supply: Antec High Current Gamer Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($119.99 @ Amazon)
Total: $2656.91
Generated by PCPartPicker 2021-10-20 12:35 EDT-0400
Personally this is what I would do for a build. You were missing a boot drive in the build so I added one.
CPU Cooler: ARCTIC Liquid Freezer II 280 72.8 CFM Liquid CPU Cooler ($109.99 @ Amazon)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory ($219.99 @ Newegg)
Storage: Western Digital Black SN850 1 TB M.2-2280 NVME Solid State Drive ($164.99 @ Amazon)
Case: Corsair 4000D Airflow ATX Mid Tower Case ($84.99 @ Amazon)
Power Supply: Corsair RMx (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($129.99 @ Amazon)
Total: $2903.91
Generated by PCPartPicker 2021-10-20 13:06 EDT-0400
I saw that video, and considering it was only a couple times he had issues with it, I do not see it as an endemic issue with ASUS's BIOS flashback. I suspect that the board in question had something wrong with it preventing the flash from working properly rather than the flash being the problems itself.
