News Ryzen 9 7945HX3D Mini-ITX PC Puts GPU Slot on Top of the Case
bit_user
Ambassador
I guess it could make sense, if you needed to swap out GPUs somewhat frequently. Still, then why not just use more of an open bench setup?
If you really plan to use it with a dGPU, then I'd rather see the case extend to enclose the GPU. If that part were as breathable as the bottom part seems to be, it shouldn't affect cooling much. This strikes me as a bit silly, especially with the PCIe power cable that's conveniently omitted from the photos.
dk382
Commendable
Aug 31, 2021
58
56
1,610
It's a bit of a weird one since this platform doesn't seem to offer any advantage over AM5 mITX. Why use a mobile CPU instead of a 7950X3D socketed into an mITX board? You can surely build a similarly sized chassis with the same features for standard mITX, but with a platform that's much more upgradeable.
Mar 24, 2023
4
Pro: No airflow restrictions
Cons: It doesn't protect what is, by far, the most expensive and vulnerable part of the PC.
As a mobile solution, I kind of like this design better than a gaming laptop. I am currently thinking of buying one but the idea of cramming a CPU and GPU into a tiny case makes me worried about longevity... So in other words, laptops are also pretty expensive and at the same time vulnerable
bit_user
Ambassador
Reactions: who_farted
